Re:jSitemap Pro: Modules as data sources? (1 viewing)
TOPIC: Re:jSitemap Pro: Modules as data sources?
#7126
Viktor
jSitemap Pro: Modules as data sources? Karma: 0
Hi everybody,
Here's my actual problem:
I made a website in Joomla which has a menu, different articles and modules in it. The articles are completely empty, and only the modules are shown on the website. The website is live since yesterday: http://www.kern-drive.com
Now I want to so the basic on-site SEO... how can I setup jSitemap pro, that it should get the content (data sources) from the modules which I use on the site and not from the (empty articles) ?
Kind regards to all of you and thank you in advance!
#7127
Re:jSitemap Pro: Modules as data sources? Karma: 84
Hi Viktor,
probably there is some misunderstand because what you say makes no really sense.
Indeed based on the Joomla architecture itself, a module NEVER generates contents or links. A module is only a presentation part of a component.
I already see links in your sitemap BTW: http://www.kern-drive.com/index.php/de/?option=com_jmap&view=sitemap&format=xml&xslt=1
Kind regards, John
