[CLOSED]Difference between two URL numbers? (1 viewing)
TOPIC: [CLOSED]Difference between two URL numbers?
#7130
Amar Guillen
[CLOSED]Difference between two URL numbers? Karma: 0
I am submitting to Google and Bing two URL sitemaps:
- the first one is the regular one:
https://www.guillenphoto.com/cms/index.php?option=com_jmap&view=sitemap&format=xml&xslt=1&lang=fr
It contains 655 URLs.
- the second one is the images sitemap:
https://www.guillenphoto.com/cms/index.php?option=com_jmap&view=sitemap&format=images&xslt=1&lang=fr
It shows 679 URLs.
Please would you tell why I have a difference of 24 URLs between the two sitemaps? It is not a big number but it can hide a bigger problem.
I have the same problem of numbers with the english version of my website?
Thanks for your help
Amar Guillen
  The topic has been closed.
#7131
Re:Difference between two URL numbers? Karma: 79
Hello again,
no worry that's not a problem at all that's pretty normal. Each sitemap has different links count based on format, language, caching, etc
#7132
Amar Guillen
Re:Difference between two URL numbers? Karma: 0
Thank you.
I trust you.
You can close the ticket.
Amar
