exclude menu external links not work (1 viewing)
TOPIC: exclude menu external links not work
#7154
Stamatis Frangedakis Kafemporiki PC / Anagnostou G
exclude menu external links not work Karma: 0
hello
i set the menu external links to excound from sitemaps but no removed.
What i do wrong?
thank you
  The topic has been closed.
#7156
Re:exclude menu external links not work Karma: 84
you have to use the parameter included in each menu data source.
And ensure that the sitemap is not cached when changing settings.
#7159
Re:exclude menu external links not work Karma: 0
i have set it to all menu data and i dont use cached.
https://athens-dayandnight.gr/cafe-bar-club/kafeneia-athina-peiraia
but i want to be like this
https://athens-dayandnight.gr/kafeneia-athina-peiraia
is any other setting where i must to do?
thank you
#7164
I still wait for your ansewrd. Can you tell me haw i can set the site map to exclound the external link, because with solution you suggest me and i was set it site maps is like before.
thank you
#7165
I already given you the answer, there's nothing more to answer. The parameter in each menu data source exclude external links included in menus if you have any from the XML sitemap, not from the HTML sitemap.
If that's not enough for you, use the exclusion system. Here you find a video tutorial too.
https://youtu.be/Qo5b2g9IRSU?list=PL6t5xIMeFJ2JG3OQASXPLi5YrFduVGWq3
Thank you for understanding.
#7169
thank you
i think that the setting is not working
nevermind thank you
