Some problems (1 viewing)
TOPIC: Some problems
#7485
Laongvivah
Some problems Karma: 0
Hi
We see the last weeks several problems, it starts with finding the xml map by Google they can’t find you say change it to sitemap/xml for a while it works not anymore.
The search engine let see old data, start with eCommerce template….. We contact for that weeblr and Joomlart both told me that it came from Jsitemap, Joomlart have repair it. Search engine meta info dashboard, let see different products then it must be, Https://www.laongvivah.com/DM-0641 let see the product DM-0104 when I look from JSitemap PRO - Search engines metainfo dashboard
The purple dress is the good one.
All the dresses in the category Fashion New they don’t let see the clear picture but a script with a picture. So as par example DM-0702, DM-0703 We talk at the moment already a week with the developers from Virtuemart, They have downloaded an backup for further investigation. First with Joomla. But all shows to Jsitemap.
Kind regards Cees Duijndam
#7486
Re:Some problems Karma: 84
sorry but i've not understood anything about your message.
If you could explain better with correct English i can try to answer you.
Kind regards
