[SOLVED]precaching not working for image sitemap (1 viewing)
TOPIC: [SOLVED]precaching not working for image sitemap
#7551
calkyk
[SOLVED]precaching not working for image sitemap Karma: 0
Version Joomla 373 et Jsitemappro 435
The XLM sitemap and XML mobile sitemap are ok, therefore I think the data sources are OK
The precaching ajax is ok for both XLM sitemap and XML mobile sitemap
the xml image sitemap is not complete
I have on my website virtuemart shop plus a lot of pictures (2600 approximatly) embedded in html articles
the image XML sitemap :
it takes the vir[tuemart shop perfectly
it starts the html articles but stops without finishing all the articles
I have read your documentation
I think it is a problem of limit of memory
I have enabled precaching ajax
with limit for images/videos sitemap = 50
resquets limit (I have tried everything with no success) - now it is on 200 - 5 min
when I try the precaching image sitemap
the first screen data source have been retrieved is ok
the second screen virtuemart category looks ok
then a red screen appears written -error- and it stopped
the precaching is not done
Can you help me to find the reason
Thanks [img size=572]https://storejextensions.org/images/fbfiles/images/sitemappro_error.jpg[/img]
  The topic has been closed.
#7552
Re:pecaching not working for image sitemap Karma: 84
to check if it's a problem of memory/timeout you should try to change the parameter for 'images/videos sitemap = 50' to a lower value than 50, for example 20 or 10 links for each step. You can assign the same value to the 'requests limit' parameter too, but that's not mandatory.
If still no luck, the problem could lie in some links related to the virtuemart products that generate an error when crawled. In such case you can try to exclude the virtuemart products data source from images sitemap to check if that helps.
Keep in mind that an images sitemap should not be generated for more than 1000/2000 links max. Crawling more links could require a lot of time and result in weird server errors.
Here you find a video tutorial that may be helpful: https://www.youtube.com/watch?v=lTvnoiFXPKk&index=1&list=PL6t5xIMeFJ2JG3OQASXPLi5YrFduVGWq3
#7553
calkyk
Re:pecaching not working for image sitemap Karma: 0
Thank for this quick answer
It works
For other people, if it can help
I have tried first
parameter for 'images/videos sitemap = 50' to 10 links for each step
It was not enough, precaching always not working
Then I was in data source and for each of them I have specified if I wanted it in the sitemap image
For exemple I have included the virtuemart products but not the categories
and not all the article for example I have no interessant image in my legal directory.
And last I don't know if it is important
I had not the same value in data source and in general configuration for the images I wanted to exclude (email, template...). I have copy the same list in data source and in general configuration
Now precaching is working for approximatly 3500 images
Thanks a lot
