Re:Exporting metainfo (0 viewing)
TOPIC: Re:Exporting metainfo
#7613
Brian
Exporting metainfo Karma: 0
Is there a way to export the meta info so that each heading in the results in in a separate column? When I use the export function I get the link, the page title and page description all in the same column. This makes it a little difficult to decipher.
Brian
#7614
Re:Exporting metainfo Karma: 84
the metainfo exports a CSV file with separated columns by ';' separator.
Ensure that you open the CSV file with a program such as Excel or Open Office configured to use that separator in order to have all columns splitted correctly.
Thanks and regards,
#7615
Brian
Re:Exporting metainfo Karma: 0
Thanks John
