Data Source for Easyblog (posts) (1 viewing)
TOPIC: Data Source for Easyblog (posts)
#7689
Jose Negron - Wide Fusion
Data Source for Easyblog (posts) Karma: 0
I setup the Data Source for Easyblog (Easyblog 5 post entries). The sitemap is generating the blog menu link, but it is not including the articles (posts).
#7690
Re:Data Source for Easyblog (posts) Karma: 84
The data source for easyblog is done to include posts.
After adding it ensure to clear the sitemap cache if any.
#7691
Re:Data Source for Easyblog (posts) Karma: 0
Hi. Thanks for your reply. I'm cleaning the cache often for others reason, but it looks doesn't have any effect on Jsitemap.
#7692
Unless you use precaching for XML sitemap, it's the same cache as for any other Joomla extension.
#7693
Hi. On the setting, both caches are disabled.
#7694
So the problem is not the cache, there is another problem.
To let me understand it, you have to contact me by email and provide a super user account.
