Htacess redirect doesn't work (1 viewing)
TOPIC: Htacess redirect doesn't work
#7748
SOHO Prospecting
Htacess redirect doesn't work Karma: 0
I need to redirect my xml sitemap from http://www.venturacountygrowsbusiness.com/index.php?option=com_jmap&view=sitemap&format=xml
to http://www.venturacountygrowsbusiness.com/sitemap.xml
I follow documentation and added this line in my htaccess file:
RewriteEngine On
RewriteRule ^sitemap\.xml$ /index.php?option=com_jmap&view=sitemap&format=xml [L]
but when i go to to http://www.venturacountygrowsbusiness.com/sitemap.xml it show me 404 page.
What I do wrong?
Please advise,
Sandra
#7749
Re:Htacess redirect doesn't work Karma: 84
i can't know this.
The correct rule for an htaccess rewriting (and not redirect as you said) is:
RewriteRule ^sitemap\.xml$ index.php?option=com_jmap&view=sitemap&format=xml [L]
without the slash as you reported. Other than this try to contact your hosting provider to ensure that your htaccess can work normally. Notice that such a rewriting is simply an alias and is not required. Best regards, John
