Re:Sitemap spliten, dauert ewig (1 viewing)
TOPIC: Re:Sitemap spliten, dauert ewig
#794
Peter123
Sitemap spliten, dauert ewig Karma: 0
Hallo,
wir haben laut JSitemap c.a 150.000 Links.
Diese müssen wir nun teilen, wenn ich nun auf Export XML gehe, dauert es ewig, es tut sich auch nichts mehr.
Es lädt und lädt und lädt, solang, bis sich Joomla selbst ausloggt.
Nach 3 Stunden habe ich dann abgebrochen, ohne Ergebnis.
Muss ich vielleicht in der Config noch etwas einstellen ?
JSitemap 2.3.3 und Joomla 2.5.27 und VM 2.6.6
PS: Bin wirklich begeistert von euren Tools, werde noch mehr kaufen !!
Weiter so, ihr steht bereits in meinen Favos
#795
Re:Sitemap spliten, dauert ewig Karma: 84
sorry could you repost the question in English? I can't understand
#796
Peter123
Re:Sitemap spliten, dauert ewig Karma: 0
hello,
we have loud JSitemap c.a 150,000 links.
This we have to share now, when I go to export XML now, it takes forever, it is doing nothing more.
It loads and loads and loads, as long as, until Joomla itself logs.
After 3 hours, I then terminated without result.
Do I perhaps set in the config something?
JSitemap 2.3.3 and Joomla 2.5.27 and VM 2.6.6
PS: I'm really excited about your tools, will buy more !!
Keep it up, it is already in my Favos
#797
Thanks for all Peter,
generating a sitemap of 150.000 in a single operation is usually impossible, it would take too much time, especially if you are using third party extensions such as Virtuemart.
For this reason has been developed the AJAX generation and precaching of the XMl sitemap.
This allows for incremental generation of very large sitemaps avoiding timeouts.
You find detailed instructions to use it in the pdf documentation.
Best regards!
#798
Peter123
Great, so I can not use your tool!
Even the Responsivizer, really awesome !!
Keep it up .. thanks for the Turbo Help
#799
Yes sure you can use it!
the AJAX precaching is a feature of JSitemap Pro.
Thanks!
