Re:Is jsitemap working with AceSEF? (1 viewing)
TOPIC: Re:Is jsitemap working with AceSEF?
#760
Inwencja Anna Kubik-Sobala
Is jsitemap working with AceSEF? Karma: 0
#761
Re:Is jsitemap working with AceSEF? Karma: 84
as far as i know there should not be any kind of conflicts.
JSitemap is not a SEF routing extension, so urls are not directly managed.
#927
marvays
Re:Is jsitemap working with AceSEF? Karma: 0
hi. i have problem with AceSEF. Ace sef generate sef url domain.com/sitemap/xml . . . i go to admin, open this sef url settings, and manualy set as sef url domain.com/sitemap.xml . . . . . . this setup save, clear cache and try it.
sef url work, but without any one page in sitemap. clear page. if i change sef url to another rondomly (/sitemappp.xml; stem.xml; /sitemap; /mapsite) all working. if i use /sitemap.xml . . . problem
#928
hi,
well i'm not a real expert of AceSEF, but it looks like a problem of alias, it seems like the alias 'sitemap' is used by something else.
However if your challenge is to have a link for the XML sitemap like this: domain.com/sitemap.xml
you can do this without using AceSEF, placing the rewrite rule in the htaccess file.
The pdf documentation of JSitemap contains explanation to accomplish this.
#935
marvays
hi.
for first, i will trying support AceSEF, but i have PRO version. thx
#936
Ok,
really i'm not sure what could be the problem.
