Re:multilingual problem (1 viewing)
TOPIC: Re:multilingual problem
#939
francy
multilingual problem Karma: 0
hi, i have a multilingual website with ARTIO JOOMSEF. With this component i cannot enable System - Language Filter so j sitemap pro doesn't show the sitemap of the languages. I try with http://www.motustriathlon.com/it/component/jmap/sitemap/xml but show 404 error. can you help me? thanks
#940
Re:multilingual problem Karma: 84
if the multilanguage plugin is disabled using a third party SEF/multilingual extension, change the setting in the JSitemap config as shown in the image below choosing 'Show always dropdown'.
This will have the effect to show the multilanguage dropdown in the SEO dashboard.
After that ensure to set the paramter 'Enable SEF links for sitemap generation' to 'No', in this way you will have raw links with multilanguage to generate different sitemaps that will work:
http://www.motustriathlon.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=it
http://www.motustriathlon.com/index.php?option=com_jmap&view=sitemap&format=xml&lang=en
