Re:Multi language problem (1 viewing)
TOPIC: Re:Multi language problem
#966
Patrick Elise Gaulin Thomas
Multi language problem Karma: 0
I need jsitemap pro to be multi-language and I have some problem to make it work.
I want to choose the "default site language" in the dropdown menu and it is blocked in the French language.
I also activated the Show always dropdown in the configuration section.
I use Falang. I don't see what's wrong in my setup.
This is the website:
http://www.altech.equipementimc.com/en/sitemap
Can you help me with that?
Thanks?
#967
Re:Multi language problem Karma: 84
Hi Patrick,
The drop-down shows the full list of all languages installed on Joomla and the default language is selected by default when page loads.
When you change language using drop-down the links for the sitemap are automatically updated appending the correct parameter lang=xxx
#968
Re:Multi language problem Karma: 0
Ok thanks, I see that.
But I wonder why my sitemap page is still in french when my I'm in the english language?
http://www.altech.equipementimc.com/en/sitemap http://www.altech.equipementimc.com/fr/sitemap
I had translated the menu in Falang. What I have to do to make it appear in both language.
#969
I think i know the reason, because Falang translates the field 'title' instead of the 'name' field used by Joomla and sitemap component.
Also for other users i attach the override file in this forum post with the instructions.
File Attachment:
File Name: falang_menu_translations.zip
File Size: 1974
#988
Thanks! It works.
But I have the same problem with the title of the page.
#989
Hello Patrick,
for the title ensure to use the standard menu titles that can be translated by Falang.
The final result should be to have different titles per each language as in the demo area also if using Falang: http://demo.storejextensions.org/jsitemap_pro
Check if the parameter for the custom override title in the component config is leaved empty.
In this way the titles of menu will be used.
