[SOLVED]Issue with fixed menu (1 viewing)
TOPIC: [SOLVED]Issue with fixed menu
#2699
Agentica Ltd.
[SOLVED]Issue with fixed menu Karma: 0
Hi folks
I am using a theme that has a fixed menu bar across the top, and am running jChatSocial as a module. Other modules I have in the sidebar slide under the fixed menu bar, but the jChatSocial slides across the top of the menu, obscuring it. I was wondering if there is an easy fix?
Thanks-
--Jeff
#2700
Re:Issue with fixed menu Karma: 84
Hi Jeff,
it looks like something related to CSS z-index.
Eventually post me the site link so i can have a look.
-John
#2701
Agentica Ltd.
Re:Issue with fixed menu Karma: 0
Hi John
www.agentica.ca
User: subscriber
Password: password
-Jeff
#2702
Hi Jeff,
you need to assign a z-index to the menu greater than the one used by the chat module.
Add the css code as below to your template:
div.menu-outer {z-index: 11000;}
#2703
Agentica Ltd.
Hi John
That was the fix. I applied the code by editing:
Template Manager >> Customize Template >> custom.css
It looks great - thanks for the super quick help! I appreciate it!
-Jeff
