A few questions on features (1 viewing)
TOPIC: A few questions on features
#371
Jacktor Wot
Re:A few questions on features Karma: 0
There is character code problem (see in attachment).
The original string: Private chat - in hungarian: Privát chat (char 'á' is problematic)
#372
Re:A few questions on features Karma: 84
This is due to the editor you are using and character encoding used.
Joomla translations files require always to use UTF-8 No Bom. Otherwise you will experiment this problem for not ASCII characters.
You can use the great Notepad++ to manage UTF8 files easily: http://notepad-plus-plus.org/
#373
Jacktor Wot
Hi again.
My problem: the chat not see the online users (see attachment) ergo the private chat funcion is unusable. .
I set the 3PD extensions integration to Community Builder and Users always online=Yes.
What is the problem?
Thx, J
"Nincsenek felhasználók" = No users (translate in progress)
#374
Hi Jacktor,
this could depend on some different factors, try to understand if disabling the CM integration the users list works normally.
Otherwise if the search field is enabled it could also be related to translations file.
Eventually contact me at my email address if you need to send me credentials for on site assist.
#375
Jacktor Wot
Thanks John, I will try some option-combination tomorrow. If those will be fail, I send you an admin access to my site.
#385
Jacktor Wot
Hi John.
So my questions are:
#1: The #1 value is okey (backend).
#2-3: Basically (by loading the main page) the value of #2 is always zero, I only see a number there if I write something to the user search input (#3). Is it possible that always the value of #1 would be seen instead of the #2? Because at the moment a zero can be seen when somebody enter to the site and he/she can think that nobody is online.
Please notify me if you need access to admin site of my webpage.
Thx, Jacktor
