Re:Fatal errors after uninstalling (1 viewing)
TOPIC: Re:Fatal errors after uninstalling
#3584
Seven Paws Press
Fatal errors after uninstalling Karma: 0
I'm getting fatal error messages after uninstalling JChat Social. I don't understand how this is happening since there is no call to JChat live on my site that I am aware of. Here's the message I'm being emailed by my error catcher plugin:
RuposTel.com plg_system_fatal_catcher plugin detected a problem with your site.
Your site caused a blank screen upon a visit of this URL:
http://www.forrestastrology.com/index.php?option=com_jchat&format=json
Error message data:
1 Call to undefined method JDocumentJSON::isHtml5() in file: /xxxxx/public_html/libraries/joomla/document/html/renderer/head.php line: 66
#3585
Re:Fatal errors after uninstalling Karma: 84
after uninstall the component and plugins there are no more calls active of course.
If you still get a server log with calls and errors reported ensure that some resources are not cached and still alive.
#3586
Seven Paws Press
Re:Fatal errors after uninstalling Karma: 0
All caches are cleared. Could it be from cached versions of the site at the user end?
