Re:Remove Tool Tip at start and How to upgrade (1 viewing)
TOPIC: Re:Remove Tool Tip at start and How to upgrade
#3817
Mary Sorani
Remove Tool Tip at start and How to upgrade Karma: 0
Hi
I have two questions that I am hoping you can help me with.
1) Whenever I log in to my profile, I get an pop up welcome message. Is there any way to disable this?
2) Also I am trying to upgrade my jchat social and it does not appear to be working. Do you have steps on how to upgrade?
Thanks,
#3818
Re:Remove Tool Tip at start and How to upgrade Karma: 84
Hi Mary,
1) Please explain me better about the profile page (it's not a feature of jchat) and about the popup welcome message (also not sure if this is part of jchat) eventually provide screenshots
2) To update the component it's enough to install the package normally though the Joomla installer, nothing else is required
#3819
Mary Sorani
Re:Remove Tool Tip at start and How to upgrade Karma: 0
Actually I seemed to have got rid of the message. I am still getting a message in JChat indicating I need to upgrade.
Also in the chat the envelope seems to be compressed. Anyway to remove this?
#3820
To update the component it's enough to install the package normally though the Joomla installer. The latest version is 2.6.1 that you can download and install.
Not sure what you mean about the compressed envelope and where it's located.
#3821
Mary Sorani
See message that JChat is outdated
#3822
That's the notice that the component is outdated, but so why don't you update it?
To update the component it's enough to install the package normally though the Joomla installer. The latest version is 2.6.1 that you can download and install to update it.
At the FAQ section http://storejextensions.org/faq.html there is 'How do I update my extension to the latest version?'
