Translation media quality (1 viewing)
TOPIC: Translation media quality
#4047
Wil
Translation media quality Karma: 0
Hello John,
In the videoscreen there is the option change media quality:
Auto
Highest
High
Average
Low
Lowest
I’m trying to translate this into Dutch but I can’t find the language string(s).
I see the words in conference.js but I know nothing about javascript so I can’t change it into Dutch.
Is there a way to translate these words or (even better) is it possible to set it on "auto" by default and disable the other options so a user can not change this anymore.
Thanks.
#4049
Re:Translation media quality Karma: 84
Hello again,
what you say is correct, these string are rendered directly by javascript code and not translated as language strings.
Disabling the Auto quality/bandwidth management option it will be set by default to 'Auto' but you can't disable all choices beucase are needed in some cases.
Thanks.
