Re:Webrtctooltip block bigger (1 viewing)
TOPIC: Re:Webrtctooltip block bigger
#4046
Wil
Webrtctooltip block bigger Karma: 0
Hello John,
I’ve got a little problem with the popup if a user want to access the videochat with internet explorer.
The popup that is showing, I translated into dutch but now the sentences are to large to fit.
Can you tell me how to make the block larger by default.
The next queston about this item:
Can you tell me how to add an extra line for the microsoft edge browser because all the new laptops here in the Nethelands are delivered with windows 10 and the browser microsoft edge.
Thanks for the help
#4048
Re:Webrtctooltip block bigger Karma: 84
Hello Wil,
dealing with the popup for webrtc support is not an easy task and requires to change and customize the javascript source code. Everything is rendered by javascript and dimensioned dynamically.
I would recommend to updated the icon of IE to match both IE and Edge that after all is the evolution of the same Microsoft browser, and to abbreviate the description to not exceed the current size.
Eventually we will add a new row in the next release
