Re:EasySocial & default rendering (1 viewing)
TOPIC: Re:EasySocial & default rendering
#5256
Agentica Ltd.
EasySocial & default rendering Karma: 0
Hi John
I am using EasySocial on my site and had been using the jChat module for rendering jChat on the site. This morning I tried out the default rendering option and quite like it. However, the default rendering leaves the Chat sidebar on top of everything in the EasySocial space - that the right side of EasySocial components, and the Joomla Top Menu are rendered underneath the sidebar, like so:
Previously with the jChat module I put
div.menu-outer {z-index: 11000;}
in my custom CSS to position the depth of the module at the right height, but it does not seem to affect the sidebar. Any suggestions? Ideally I would like the menu bar to be fixed with the sidebar fixed to the right, but with its top below the menu bar. Thanks -Jeff
#5257
Re:EasySocial & default rendering Karma: 84
Hi Jeff,
the chat bar is done to stay on top of everything and avoid risk to be covered.
If you want an element to stay over it using the z-index, probably you have to specify the CSS rule:
position: fixed;
for that element, otherwise it won't work.
