How to enable/disable Administrator Interface (1 viewing)
TOPIC: How to enable/disable Administrator Interface
#5549
Mark
How to enable/disable Administrator Interface Karma: 0
How can I show / hide JChatSocial Administrator Component from the Component Listing?
I see it listed and available for the Super User. But I'd like to add it to a limited admin account.
The per group access permissions is not a part of the JChatSocial configuration.
#5550
Re:How to enable/disable Administrator Interface Karma: 84
indeed this can't be done. The admin interface is available for all admin user groups. Permissions are for the frontend actions.
#5551
Mark
Re:How to enable/disable Administrator Interface Karma: 0
John, I have a similar issue as another user on here where my chat always says 0 users online. In the past it worked perfectly. Through some update, not sure which, it stopped working.
I wanted to make a support login for you to check it, but I wanted to limit the admin components.
#5552
Hello Mark, ensure that the configuration is correct and that the Joomla! configuration has the session management set as by default for 'database'
I don't think that the problem arised after an update.
#5553
Mark
John Dagelmore wrote:
Session Handler = Database
