J!Extensions Store™
Re:jchat embedding as its own page instead of sidebar? (1 viewing)
TOPIC: Re:jchat embedding as its own page instead of sidebar?
#5874
AP3
jchat embedding as its own page instead of sidebar? Karma: 0
Hi I just bought your jchat extension last night and i was hoping that i could incorporate it as its own page on my joomla. In other words, instead of having the sidebar feature, is it possible to have a link in my menu titled CHAT ROOM and then when people click on it, it would take them to a different page in my joomla where the chat room would be 'embedded'?
If that is not possible, then would it be possible to set it up as a module on the homepage of the website?
If either of these options are possible, can someone please explain to me how?
Thanks in advance for helping me.
Don
#5875
Re:jchat embedding as its own page instead of sidebar? Karma: 79
Hi Don,
having it as a component linked to a menu is possible only for certain views, for example the private messaging view, you find the available component views when you create a new menu item.
Although the main purpouse of the app is to have a sidebar rendering, it's also possible to manage it as a module. There are detailed explanations about this in the PDF docs at the paragraph 'Chat rendering'
I've written a very detailed PDF docs so that referring to that you will find almost everything you need to know on this app.
#5876
AP3
Re:jchat embedding as its own page instead of sidebar? Karma: 0
Thanks for the quick reply John. I tried following the docs but couldn't seem to get it to work that way. Having said that, i am using a theme from rockettheme under the gantry 5 framework they have. I'm wondering if that may have something to do with it
#5877
I don't think that Gantry 5 makes any difference in the Joomla modules management. However try to perform some tests using even the default standard template.
#5878
AP3
i feel kinda stupid for not thinking of that before. I'll be sure to give you the feedback as to whether it worked in the default template or not. Thanks
#7283
Nate Covington
Try this:
- Change JChat mode to operate as a module instead of in the footer
- Edit your JChat module and change the module position name to "livechat"
- In your "Live Chat" article, embed the module using {loadposition livechat}
