Re:404 error when I click on an avatar (1 viewing)
TOPIC: Re:404 error when I click on an avatar
#7569
Nicolas Wojtowicz
[SOLVED]404 error when I click on an avatar Karma: 0
I'm using Kunena ( I declare it in '3PD extensions integration'
I have joomla 3.7.3
If I click on my avatar in a conversation window, it tries to go to 'https://.../index.php/component/kunena/?view=user&userid=..' and ends with a 404 error.
The avatars are working well using kunena
Thanks.
Nicolas
#7570
Re:404 error when I click on an avatar Karma: 84
i ignore why you get this 404, maybe you have some 3PD extensions to manage SEF that conflict.
Some hints:
1. Try to select a menu item for the social extension as in the screenshot attached
2. Open the file root/components/com_jchat/models/stream.php and change the line 2902 from:
$profileLink = JRoute::_('index.php?option=com_kunena&view=user&userid=' . $id . $Itemid);
to:
$profileLink = JRoute::_('index.php?option=com_kunena&view=profile&userid=' . $id . $Itemid);
I've no other ideas. Thanks John
#7583
Nicolas Wojtowicz
Re:404 error when I click on an avatar Karma: 0
Hacking stream.php didn't work, but selecting a menu item for the social extension works! so no more 404 error.
Thanks.
Nicolas
