Links gone (1 viewing)
TOPIC: Links gone
#116
Tom Kuyper
Links gone Karma: 0
I've lost all the correct links from my menu's. (404)
The URL is pointing towards www.xxx.com/xxxx instead of www.xxx.com/index.php/xxxx (index.php missing)
Any ideas?
Tom
#117
Brandon Savage
Re:Links gone Karma: 0
Hi Tom,
This should be normally related to htaccess rewriting and the param in Joomla configuration to enable url rewriting.
Try to check this settings, having not htaccess enabled you need to leave of url rewriting and so keep the index.php in your urls.
#118
Tom Kuyper
HI,
It was the url rewriting in Joomla.
Thanks for your help!!
Tom
#119
Re:Links gone Karma: 84
[Resolved]
That's great!
