[Solved] Slideshow not working (1 viewing)
TOPIC: [Solved] Slideshow not working
#1180
Bilal
[Solved] Slideshow not working Karma: 0
Slideshow not working on my mobile website. I'm using newest version of responsivizer with joomla 3.2. I followed everything on the document and demo and everything seems fine in the back-end but the slideshow doesn't appear on the phone. Tried different position for the slideshow and different pages and all seem not working....Tested on responsivizer phone emulator, samsung s5 chrome,Firefox and htc one v android browser non seem to show the slideshow. After debugging through chrome on S5 it appears the html code is loaded and java script as well, but nothing is showing on the page.
Thanks,
#1181
Re:Slideshow not working Karma: 84
normally it's enough enabling the slideshow in the component config, the module is already in place assigned to position responsivizer_slideshow.
Post the link to your site so we'll be able to have a look, it could be a problem of javascript.
#1182
Bilal
Re:Slideshow not working Karma: 0
Here's my Website [url=http://www.fitnesstime-lb.org[/url] ..... I already disabled most of the modules on the home page except for some icons and responsivizer slideshow and it's position is set to responsivizer_slideshow
Thanks,
#1184
Yes there are javascript errors, probably due to these scripts loaded just before the final </head> tag at invalid position:
<script type="text/javascript" src="/libraries/videobox/js/jquery.min.js"></script><script type="text/javascript">jQuery.noConflict();</script> <script type="text/javascript" src="/libraries/videobox/js/videobox.js"></script> <script type="text/javascript" src="/libraries/videobox/js/functions.js"></script>
Try to disable and check if it solves.
#1185
Bilal
Thanks! that was so helpful. I disabled the videobox plugin which I'm not using anyway and it worked.
#1186
Great! I noticed that the videobox loaded jquery files without following Joomla standards, hence the problem.
