Re:Using separate articles depending on device (1 viewing)
TOPIC: Re:Using separate articles depending on device
#149
Re:Using separate articles depending on device Karma: 84
Hi Micke,
normally this is done for home page and the component is able to manage that using the feature for custom home page.
If you have multiple pages that should contain different contents based on device/template, the best approach would be using different menu, one for desktop and one for mobile template with items that can be customized as preferred pointing to different contents.
