Is it possible to create more than one slide show? (1 viewing)
TOPIC: Is it possible to create more than one slide show?
#1714
Multi Ingenium
Is it possible to create more than one slide show? Karma: 0
I was trying to create more than one slide show but couldnt find the way in the documentation. thx 4 ur answer
#1716
Re:Is it possible to create more than one slide show? Karma: 84
Hi all,
currently more than one slideshow can't be created. You can use one of the available slideshow modules for Joomla to add multiple modules to site pages.
