Re:Go to Top function (1 viewing)
TOPIC: Re:Go to Top function
#1778
Larry Crain
[SOLVED]Go to Top function Karma: 0
The "Return to Top" button/text shows, but does not function when using the code:
"<a id="gototop" href="#topofthepage" style="opacity: 1; visibility: visible; position: fixed; display: block; right: 0px; bottom: 0px;">Return to Top</a>"
It works fine on the full website, but not on mobile. An example is at www.websitescr.com
#1780
Re:Go to Top function Karma: 84
Hello Larry,if you are using a plugin for topofpage, it could be the cases that the javscript is not compatible with mobile.
Also i had a look to your mobile site and it seems that the gototop button needs an additiona z-index to be clickable
john
#1782
Larry Crain
Re:Go to Top function Karma: 0
Great and fast service, John.
I added the z-index to the Top of Page and now it works on mobile. Thank you.
#1783
Thanks Larry
