Re:Slideshow, articles and single modules (1 viewing)
TOPIC: Re:Slideshow, articles and single modules
#1822
Sophie Bevan
Slideshow, articles and single modules Karma: 0
Hi, excellent product - very happy, thank you!
I need to tweak things a bit but am not too good with the css files. I'm still on Joomla 1.5. (will be updating to 3x in the very near future)
I would like to make the slideshow a little smaller height-wise; even though I have resized the images, making them smaller, and changed the "minimum height" setting in the menu it hasn't made any difference.
Another question - is there any way I can eliminate my lead article from the mobile front page? I don't like the layout it has on the mobile site..
Last question (for the moment) - How can I move my "search" box, which on my site is in the "right" position, to the bottom of the mobile page? Without moving all the other module items currently in the "right" position?
My site is www.miomatrimonio.com
Thanks in advance for any help!
Sophie
#1823
Re:Slideshow, articles and single modules Karma: 84
Good morning Sophie, thank you very much
About the slideshow, check if the setting 'Images auto height' is set to 'No' after have changed the min height for the slideshow, that could be the problem.
To eliminate the lead article the easiest way should be hide it using CSS, and finally to move the search box to the bottom, you can exclude the current one in right position using the exclusion switcher in the modules manager of Responsivizer, then clicking on 'make mobile' button create a new instance and position it to one of the bottom positions, for example 'responsivizer_bottom'
If you need to talk with me or if you need my help, please contact me directly at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it
Best,
