Re:Installation problem Joomla 2.5.11 (1 viewing)
TOPIC: Re:Installation problem Joomla 2.5.11
#1872
Jonathan Roth
Installation problem Joomla 2.5.11 Karma: 0
I'm trying to install the: responsivizer_v2.1.1_forjoomla1.6_1.7_2.5.zip file on joomla version 2.5.11 and I'm getting,
JFolder::create: Could not create directory
Warning: Failed to move file!
Can anyone help
#1873
Re:Installation problem Joomla 2.5.11 Karma: 84
Hello Jonathan,
it's a proble due to folder permissions of the Joomla installer, refer to this FAQ: http://storejextensions.org/faq/i-receive-an-installation-error-when-installing-component-what-could-be-the-problem.html
Eventually contact me if you need some info, usually you need to access by FTP to change chmod on Joomla folders.
#1874
Jonathan Roth
Re:Installation problem Joomla 2.5.11 Karma: 0
Thanks for the quick reply, I have checked and the tmp folder says unwritable but I have uploaded K2 and other components to the site, without a problem. I have FTP access what should the CHMOD setting be for the tmp folder? currently set at 755
Thanks Jonathan
#1875
#1982
douglasdatasystems
Hi All,
I had this same problem and found my configuration.php contained incorrect information, the following helped resolve the problem:
http://stackoverflow.com/questions/15802419/jfoldercreate-could-not-create-directory-joomla
Cheers
d_a_w_g_y
#1983
Hi dear,
thank you very much to post the stackoverflow link.
This is a known issue also documented at this FAQ: http://storejextensions.org/faq/i-receive-an-installation-error-when-installing-component-what-could-be-the-problem.html
Cheers
