Problem in blog view (1 viewing)
TOPIC: Problem in blog view
#1880
Dimagias SRL
Problem in blog view Karma: 0
sorry for my poor english
I have one problem with blog view for category
For example, in the Page Cathegory, althow it is set to view only "Intro Text", for all the articles it shows full text, in the same time, the title of the article is missing.
The next problem is that the blog view category's social media buttons from have the wrong direction link to category and not for the article.
Exemple here http://www.mamicamea.ro/sanatatea/
For "Intro text" i use plugin http://extensions.joomla.org/extension/read-less-text
This problems appear no matter the setting imply template "Responsivizer" or any other personal template responsiv.
Another problem I noticed in the article's view mode, althow I set Position of Article Info BELOW Contents, with Responsivizer Template, Article Info (Category and Author) is shows ABOVE Content of Article.
Thanks for the help
#1882
Re:Problem in blog view Karma: 84
#1885
Dimagias SRL
Re:Problem in blog view Karma: 0
I send email
I waiting answer
#2218
Dimagias SRL
the problem occurs again with both template: desktop and Responsivizer
but just under some categories, example
mamicamea.ro/despre-sarcina/
mamicamea.ro/sarcina-pe-saptamani/
To another categories works ok, example
mamicamea.ro/sarcina-si-nasterea/
If you disable Responsivizer, everything returns to normal
#2219
What was the problem ? The article titles missing? I remember we worked on that some time ago but i don't remember what was the solution
#2220
Dimagias SRL
I senf again login details
