Installation Problem (1 viewing)
TOPIC: Installation Problem
#1883
Martin
Installation Problem Karma: 0
Hi Just got the plugin, installed it fine but when I click on "Components > Responsivizer" I just get a white screen. When I go to "System > Config > com_responsivizer" I get the following message
"1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AS , AS FROM WHERE = 0 AND != 'responsivizer'' at line 1 SQL=SELECT DISTINCT AS , AS FROM WHERE = 0 AND != 'responsivizer'"
when accessing the site's front end you get "Fatal error: Call to undefined method JSite:et() in /home/sites/grangephotography.co.uk/public_html/plugins/system/responsivizer/responsivizer.php on line 40 "
Any ideas?
#1884
Re:Installation Problem Karma: 84
Hello Martin,
it looks like the version of Responsivizer installed doesn't match the correct Joomla version.
If you are using Joomla 3 the package to be installed is named as: responsivizer_v2.1.1_forjoomla3.x.zip
Let me know if you need on site help.
