Re:Questions Prior to Buying (1 viewing)
TOPIC: Re:Questions Prior to Buying
#1973
Jonathan
Questions Prior to Buying Karma: 0
Hi, I am considering buying this item, just have a few questions if okay.
If I install the item, does it affect the non-mobile view of the site at all? I.e. is there the risk that I install it, and it causes some kind of fault with the template, modules, layout etc of the current site?
If I install the item and it doesn't work, when I uninstall it from the site, will the site return to exactly as it was prior to before I installed the Responsivizer?
Please don't get me wrong - I am not foreseeing or expecting problems, I am just erring on the side of caution! Appreciate help in advance.
Many thanks
#1974
Re:Questions Prior to Buying Karma: 84
Hello Jonathan and thanks for interest,
1. normally not, the mobile template is completely separated and independant from the current desktop site
2. yes, apart from the fact that you may need to create some modules for the mobile layout. In this case you will need to delete them in the Joomla modules manager
#1975
Jonathan
Re:Questions Prior to Buying Karma: 0
Hi - no you replied so quickly it gave me confidence in the product!
I have now bought it, and will see how I get on. Any problems / questions, I will of course drop you a line, and thank you again for the quick reply.
#1976
Thank you Jonathan, i do my best
