Re:Location of Switch to deskop (1 viewing)
TOPIC: Re:Location of Switch to deskop
#1978
Doncy
Location of Switch to deskop Karma: 0
The "Switch to desktop site" is now located at the bottom. Is there a way to have it at the top of the site?
Many thanks!
Luc
#1980
Re:Location of Switch to deskop Karma: 84
Hello Luc,
to move up the location you need to edit the index.php of the template. You will find the following code:
<!-- bottom switch tpl --> <?php if ($showTplSwitcher && !$switchAlways) : ?> <div class="bottom_switcher"> <ul> <li> <i class="fa fa-desktop"></i> <a href="<?php echo $queryStringToDesktop;?>"><?php echo JText::_('TPL_RESPONSIVIZER_DESKTOP_VIEW');?></a> </li> </ul> </div> <?php endif; ?>
#1981
Doncy
Re:Location of Switch to deskop Karma: 0
Thanks!!
Luc
