Re:Using the helix framework, template switching doesn't seem to be working by default in joomla 2.5.17 (1 viewing)
TOPIC: Re:Using the helix framework, template switching doesn't seem to be working by default in joomla 2.5.17
#1996
Re:Using the helix framework, template switching doesn't seem to be working by default in joomla 2.5.17 Karma: 84
The plugin orders is correct.
Last check you can do is put the site online, ensure that the Joomla SEF and the template switcher settings are correctly enabled, then clear cookies on your mobile device.
