Re:Customizing footer (1 viewing)
TOPIC: Re:Customizing footer
#2067
Re:Customizing footer Karma: 84
this must be ruled directly in the index.php file of the template to change the order of HTML elements,
for example the phone number section can be moved before the copyright text changing from:
<?php if($copyright = $this->params->get('copyright_footer_html', null)): ?> <div class="copyright"> <div class="module nobg"> <?php echo $copyright;?> </div> </div> <?php endif; ?> <div class="clr"></div> <!-- tel phone number tag --> <?php if ($telNumber) : ?> <div class="bottom_tel_number"> <a href="tel:<?php echo $telNumber;?>"> <i class="fa fa-phone-square"></i> <?php echo $telNumber;?> </a> </div> <?php endif; ?>
to:
<?php if($copyright = $this->params->get('copyright_footer_html', null)): ?> <!-- tel phone number tag --> <?php if ($telNumber) : ?> <div class="bottom_tel_number"> <a href="tel:<?php echo $telNumber;?>"> <i class="fa fa-phone-square"></i> <?php echo $telNumber;?> </a> </div> <?php endif; ?> <div class="copyright"> <div class="module nobg"> <?php echo $copyright;?> </div> </div> <?php endif; ?> <div class="clr"></div>
or moving the section for the phone number in the preferred order:
Greetings, John
Customizing footer
Queenb Creative, LLC
thread linkthread link Re:Customizing footer
