Menu not showing (1 viewing)
TOPIC: Menu not showing
#2070
Fred Belanger
Menu not showing Karma: 0
When I browse to the site boyermountaindoorandpool.com the menu does not show up at all. I'm using the defaults for the settings. Any help appreciated.
Thank you.
#2071
Re:Menu not showing Karma: 84
Hello Fred,
normally it requires that you assign the menu to a position of the mobile template of Responsivizer, such as 'responsivizer_mainmenu'
If you have already an instance of the module for the desktop template using the button 'make mobile' you can easily migrate it to the mobile layout.
The menu management for mobile is explained in great details in the pdf docs at the partagraph 'Mobile menu positions and management' and an example is visible in the video: https://youtu.be/B1fqydcZYlI
