Re:drop down menu not working (1 viewing)
TOPIC: Re:drop down menu not working
#2086
Lynette Basta
drop down menu not working Karma: 0
Good evening. The drop down menu is not working properly. The main menu is displayed correctly and it show the arrows but the arrows do not bring me to the next menu. www.bastaboatlifts.com
Thank you in advance for your help!
#2087
Re:drop down menu not working Karma: 84
Hello Lynette,
the menu that you are using on mobile is the same as the desktop, and it seems not working well on mobile.
You should exclude it and use the built in mobile menu of Responsivizer.
