Re:[SOLVED]Using Joomla 2.5.27, emulator problem (1 viewing)
TOPIC: Re:[SOLVED]Using Joomla 2.5.27, emulator problem
#2117
Ross McClenahan
Re:[SOLVED]Using Joomla 2.5.27, emulator problem Karma: 0
Hi John, I was experiencing the same issue (in J1.5) and fixed it per this thread (disabled Akeeba Admin Tools). However I would still like to run Admin Tools. Can you please provide a compatible setting that will allow the evaluator to work and the template changer script to run? Thanks!
