Re:Problem on design issue (1 viewing)
TOPIC: Re:Problem on design issue
#2187
Re:Problem on design issue Karma: 84
Hi, first of all thank you very much to like our extension and work
About your questions:
1. Needs some CSS customization to remove the background image with 3 lines and add a textual label. The easiest way is add a label using CSS with :after pseudo class and the 'content' property. This avoid the need to override the extension file (see image attached)
2. Assign a float:left to the 'li' elements (see image attached)
3. Probably there is an empty module with no output still assigned to the position 'responsivizer_left'. Once you find it you can delete the module or use the button to 'Mobile exclude' it
4. Some CSS are required in order to increase the size of the 'td' element of the table currently set to 104px, the use a text-align: right (see image attached)
If you need some CSS customization, we offer on site service. In any case contact me directly at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it .
KYD, Inc
thread linkthread link Re:Problem on design issue
thread linkthread linkthread link Re:Problem on design issue
thread linkthread linkthread linkthread link Re:Problem on design issue
KYD, Inc
