No Menus (1 viewing)
TOPIC: No Menus
#2310
qwe
No Menus Karma: 0
Hello, I installed responsivizer in an existing web page.
After reading documentation and trying a number of options, I did not succed in getting almost anything preexistent (just a bottom module that I assigned).
My template is based in Gantry and the menu is not a module, so I can not assign it.
Will I need to create my own customized menus in responivizer?
Thank you very much.
PD: I have the plug-ins un the correct order.
#2311
Re:No Menus Karma: 84
if you used a desktop template like Gantry without a real menu module you need simply to create a new default Joomla module for the site menu and assign it for example to the position 'responsivizer_mainmenu'
It will be rendered automatically as a mobile menu by Responsivizer.
In the pdf section 'Mobile menu positions and management' you find detailed explanations about menu of Responsivizer and template positions.
As a side not, if your Gantry template has module assigned to its own template positions, you can quickly map them to the Responsivizer ones using the 'Positions associations' feature.
#2316
qwe
Re:No Menus Karma: 0
It worked, thank you!
