Joomfish not working on Joomla 1.5+Responsivizer (1 viewing)
TOPIC: Joomfish not working on Joomla 1.5+Responsivizer
#2363
Yuriy Boev
Joomfish not working on Joomla 1.5+Responsivizer Karma: 0
We are almost ready with our mobile version of https://www.growshop-bg.com, but now I have noticed that Joomfish is not translating our site.
Joomfish version is 2.0.3 and Joomla version is 1.5.26
What I have noted is that on the mobile version the URL is: https://www.growshop-bg.com/index.php/ventilatsiya
and on Desktop it is: https://www.growshop-bg.com/ventilatsiya
I wonder where this additional index.php is coming from and thus breaking Joomfish?
#2364
Re:Joomfish not working on Joomla 1.5+Responsivizer Karma: 84
Hello Yuriy,
as far as i know this is not a problem of Joomfish.
The problem is the System - Legacy Plugin for the old Joomla 1.0 that when enabled adds the string 'index.php' on mobile.
Unpublishing it will solve the problem and also will speed up the site.
#2365
Yuriy Boev
Re:Joomfish not working on Joomla 1.5+Responsivizer Karma: 0
Sure, but this will break other stuff.
I am not the one who build the site and I don't know what else will break up.
Is there any hack for this plugin to work properly?
#2366
You can try to comment out the line 49 of legacy.php:
// $config->setValue('config.legacy', 1);
This should avoid the url problem on mobile.
#2367
Yuriy Boev
Great stuff!
Thanks for the outstanding support
#2368
