Re:Mp3 player not working in mobile view (1 viewing)
TOPIC: Re:Mp3 player not working in mobile view
#2380
Tim Orgias
Mp3 player not working in mobile view Karma: 0
Hi, I have just installed the Quicksell component which uses an mp3 player to preview tracks that can be purchased. The player works well on desktop view, but does not work on mobile view.
Is there anything I can do in responsiviser to enable this?
Please see the link here to try for yourself. http://www.inrhythm.com.au/bp-register-thank-you
Thanks, I look forward to your reply
Cheers
#2381
Re:Mp3 player not working in mobile view Karma: 84
Hi Tim,
just had a look and a try to your site.
The player behavior is not related to responsivizer, that manage only the layout.
Looking at the player, i see that it comes from a component 'com_quicksell' and it seems Flash based. If so probably this is the problem, most mobile devices supports HTML5 player but no more Flash, especially Apple devices.
In this case the only solution would be update the player to an HTML5 one, supported by all mobile devices.
PS: on my Android i was able to use your mp3 player.
