Menu and submenu animations (1 viewing)
TOPIC: Menu and submenu animations
#2673
Peter Ulrich
Menu and submenu animations Karma: 0
My submenus are long and do not lend themselves well to dropping down under the main menu heading. I would like to have each submenu accordian open to the right (effectively covering the higher level menu). Is that possible?
#2674
Re:Menu and submenu animations Karma: 84
Hello Peter,
the mobile menu supports 2 different working mode, 'accordion' and 'dropdown'
If the accordion is too long for you, try to switch to 'dropdown' mode so that submenus will be showed besides of the parent.
