Re:modules mobile exclude (1 viewing)
TOPIC: Re:modules mobile exclude
#271
Carlo B.
modules mobile exclude Karma: 0
if i choose as mobile template the same of the site, is it possible with respinsivizer exclude a module only from mobile? I tried without success modules manager->mobile exclude->yes
#272
Re:modules mobile exclude Karma: 84
Hi Carlo,
the modules manager is a feature of responsivizer, so using a third party template it's skipped and can't work.
You need to use the built in engine and template to use that.
