Re:Mouse Over in Control Panel Colors (1 viewing)
TOPIC: Re:Mouse Over in Control Panel Colors
#2771
Allan Denholm
Mouse Over in Control Panel Colors Karma: 0
Hi
I have only just installed Responsiviser and have hit an immediate problem!
When I mouse over an option in the HMI, the explanatory pop up box for what that function does appears, but with white text on a yellow background!
Appreciate your advice on where to change this for a more legible color combo....
Thanks!
#2772
Re:Mouse Over in Control Panel Colors Karma: 84
Hi Allan,
not sure what you mean with HMI.... i guess you are talking about popup box in the admnistrator interface.
If so, this is not normal because popup must be black with white text. Of course i know nothing about your setup, Joomla version, etc and your would be the first case.
#2773
Allan Denholm
Re:Mouse Over in Control Panel Colors Karma: 0
Hi John
Thanks for getting back to me so quickly!
So in your screenshot - where you have the "Enable custom default text color...." pop up box, you have white text on a black background, I have white text on yellow... See attached.
I am running Joomla 2.5.14 on Windows 7 Professional - let me know what else you might need to advise?
Thanks again
Allan
#2774
