Changes to Virtuemart aren't reflected in mobile site (1 viewing)
TOPIC: Changes to Virtuemart aren't reflected in mobile site
#3045
Clint Lanier
Changes to Virtuemart aren't reflected in mobile site Karma: 0
Hello, the site is at www.younggunsproduce.com.
I recently modified the code in the "categories" display for Virtuemart so that it hides the "add to cart" button from the category display because it was causing problems. On the desktop site the changes are reflected, there is no longer an "add to cart" button on the categories page (see here: http://younggunsproduce.com/shop-online/hatch-green-chile)
However the "add to cart" button still shows up on the mobile site using responisvizer. I've cleaned the site's cache completely but that doesn't seem to help. Do you have any ideas?
#3046
Re:Changes to Virtuemart aren't reflected in mobile site Karma: 84
Hello Clint,
it looks like you are using a template override for Virtuemart. I guess that you have modified the "add to cart" inside the override of the desktop template. This of course affects only the desktop template, not the mobile one.
Copy the override also under the 'responsivizer' template to apply to the mobile too.
Kind regards,
#3047
Clint Lanier
Re:Changes to Virtuemart aren't reflected in mobile site Karma: 0
Slow clap! Thanks so much, I knew it had to be something like that, just didn't know where it went.
The problem is solved, thanks for the fantastic and quick help!
#3078
Artem Popov
Im having a similar problem. I removed the code for a sort by selection on my desktop virtue mart categories page.
on the desktop its no longer showing up but on the mobile its still showing up.
i have tried to remake the already edited module mobile but it hasnt solved it. where can i find the file for the mobile category code?
#3079
Hi guys,
the problem with Clint was related to template overrides. If you have a template override for Virtuemart placed in your desktop template and you customized it, it must be copied also in the folder of the mobile template:
yourdesktoptemplate/html/com_virtuemart -> responsivizer/html/com_virtuemart
#3083
Artem Popov
awesome, thank you.
no wonder i couldnt find the mobile version files. responsivizer/html/com_virtuemart, "com_virtuemart didnt exist in the responsivizer folder. i added it and all is good.
Thank you again
