Not working (1 viewing)
TOPIC: Not working
#3075
Magis Design e.U.
Not working Karma: 0
Hello. I installed the plugin on my site, but if I click on the emulator the website on the phone is completely white... (nothing is shown) also on mobile devices I get a white window.
What is the problem? http://bit.ly/1EtwH0x
#3076
Re:Not working Karma: 84
just looked at your site. Indeed it works but shows completely empty, because probably the desktop template 'templates/theme984' uses all proprietary positions for modules and nothing is mapped to mobile.
Try for example to add the logo to the mobile responsivizer, the menu, etc and they should show normally.
Let me know if you have questions or need help.
#3077
PS: also a quick way to map desktop modules/positions to mobile is using the 'Positions associations'
#3080
Magis Design e.U.
Re:Not working Karma: 0
I gave a few modules the position in the mobile, but it still not works!
in the backend I uploaded to responsivizer a logo. It worked fine. After that I went to the module-section and tried to put a module in the right mobile position and saved it, but after that I opened it on my phone - still not working.
#3081
#3082
Magis Design e.U.
Thank you. I already sent you an email.
