Re:Remove top left slide-out menu? (1 viewing)
TOPIC: Re:Remove top left slide-out menu?
#3261
Tad Brunye
Remove top left slide-out menu? Karma: 0
Hello -
Great extension. How do I remove the top left menu button that makes the category list slide out from the left?
Do not see an option to disable/remove that anywhere.
Thanks!
#3262
Re:Remove top left slide-out menu? Karma: 84
Thanks Tad!
That sliding button is showed automatically when there are some modules assigned to the position 'responsivizer_menu_left'
Remove all the associations under 'positions associations' with this template positions and the button will vanish.
