Re:After installation getting Error on back and front (1 viewing)
TOPIC: Re:After installation getting Error on back and front
#328
Tanya Flores
After installation getting Error on back and front Karma: 0
Test site: http://teamflores.com/40kickoff/
After installation (installed successfully notice displayed) I accessed the Responsivizer control panel and have this error:
Error
Table 'teamaqpm_40kickoff.j1q8j_rvzr_modules' doesn't exist SQL=SELECT COUNT(*) FROM `j1q8j_modules` AS m LEFT JOIN `j1q8j_rvzr_modules` AS r ON m.id = r.id WHERE m.client_id = 0 AND m.position IN('responsivizer_language_switcher','language_switcher','language','responsivizer_menu_top','top_menu','topmenu','responsivizer_logo','logo','banner','responsivizer_mainmenu','menu','mainmenu','responsivizer_search','search',' responsivizer_breadcrumb','breadcrumb','pathway','responsivizer_top','top','responsivizer_left','left','responsivizer_right','right','responsivizer_slideshow','slideshow','carousel','responsivizer_user1','user1','responsivizer_user2','user2',' responsivizer_user3','user3','responsivizer_user4','user4','responsivizer_user5','user5','responsivizer_user6','user6','responsivizer_bottom','bottom','responsivizer_copyright','copyright','responsivizer_menu_bottom','bottom_menu',' responsivizer_debug','debug' AND m.published >= 0
Front end error on mobile device:
1146 - Table.... (I attached screen prints)
#329
Re:After installation getting Error on back and front Karma: 84
Are you performing a fresh installation of responsivizer or is it an upgrade from old version 1.0?
This kind of error is typical of updating to version 2 from version 1.
Version 2 of component has been completely rewritten and in that case you need to uninstall old version before updating.
Keep a backup copy in case of css customization.
Kindest regards
#331
Tanya Flores
Re:After installation getting Error on back and front Karma: 0
This was a fresh install of responsivizer_v2.0_forjoomla3.x.zip on Joomla 3.3.1
I'll uninstall and try again.
Tanya
#332
Hi Tanya,
the error is related to database table. Eventually after installation check if in Joomla database the table 'rvzr_modules' has been correctly created.
On fresh installation that table is created without problems, otherwise some other issue could be responsible.
#333
Tanya Flores
Re:After nstallation getting Error on back and front Karma: 0
Solved John with the uninstall, reinstall. Thanks! LOVE Responsivizer!
#334
Re:After nstallation getting Error on back and front Karma: 84
Probably some dirty tables still was in database
Have a nice day Tanya!
