Re:Drop-down menu doesn't work (1 viewing)
TOPIC: Re:Drop-down menu doesn't work
#3427
John Watkins
[SOLVED]Drop-down menu doesn't work Karma: 0
Using v2.2
Page: http://www.rscdsedinburgh.org/index.php/pay
The drop-down menu does not work on either smart phone or the Mobile Emulator.
#3428
Re:Drop-down menu doesn't work Karma: 84
Hello John,
probably a conflicting issue on mobile with the drop-down markup.
Set the following parameter to 'Yes' to avoid conflicts, probably it will solve:
#3429
John Watkins
Re:Drop-down menu doesn't work Karma: 0
Thank you for your speedy response. Yes, that fixed the problem. Many thanks.
